For information you can push the pin out from the cable end but only on early handles as it's not blanked off at the back. The later handles are blanked off at the back but you can tap the pin at the other end to knock a piece out of the back, it actually breaks away very neatly as it's very thin. You can then push the pin out easily. This is the preferred method I recommend with my kits. I've used this method many times with complete success.
