Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: G60 weird idle???
  1. #1
    G60 weird idle???
    So let me start by saying that its been like this since i got the car, cold start the car idles fine. After warming up or giving any gas at all the idle surges like crazy...
    Tested and cleaned my isv and it functions the way it should.
    Any help is greatly appreciated
  2. #2
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    1,996
    Hi mate,
    Could be many things as these cars are getting old now..
    Start by checking the small throttle body switchs, 1 is for idle and the other is for full power enrichment, check that the idle microswitch closes with the throttle closed, you'd normally hear an audiable click.
    Next up, the Lambda sensor, in particuler its wiring that goes rock hard and snaps off the terminals on the plug, always worth redoing the terminals with new ones.
    Change the blue headed coolant sensor or temp. just swap over the two plugs, 1 black for the intrument cluster gauge whilst the other is used to send a signal to the Digifant in jection ecu.
    Let me know how you get on.
  3. #3
    Im not getting a click when the throttle opens, how would i go about replacing the switch?
  4. #4
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    1,996
    Just try adjusting the Switch, there are two small screws that locate the idle Switch on a bracket, on the back of the throttle body. Loosen them both until the switch actually clicks closed or use a multimeter.
    Lock up both screws and see if the idle has improved.
  5. #5
    Adjusted it and am now getting an audible click, still having a rough idle problems
  6. #6
    Correction lol I'm getting a click from the switch at the front of the throttle body when a t full throttle. The switch at the back may be missing the cover that has the arm on it. Not sure what its suppose to look like. You would happen to have a pic would you
  7. #7
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    1,996
    No mate, been turbo 16v For years..mine's Got an Escort cosworth throttle body..
    Try snapping a photo of Your throttle body, if you can upload them on the forum.
    Try this, start the Engine then try depressing the idle micro switch and see what happens, the open the primary butterfly a little, hold it at around 2000rpm then depress the full throttle switch, the engine note should change as the mixture is enriched.
    Let me know.
  8. #8
    Regular
    Join Date
    15th October 2008
    Location
    West Yorkshire
    Posts
    140
    Another common issue is the rubber o-ring on the idle screw on the throttle body perishing, worth removing the screw and checking it
  9. #9
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    1,996
    And refitting the little bugger with a few strands of plumber's PTFE tape to avoid loosing it..
  10. #10
    Enthusiast
    Join Date
    4th March 2010
    Location
    Berkshire
    Posts
    573
    Quote Originally Posted by that_black_G60 View Post
    Here you go....
    Attached Images Attached Images
Similar Threads
  1. raised idle and fast idle problems on G60.
    By Redfox in forum Engine Bay
    Last Post: 28th April 2015, 8:57 AM
  2. Temp Senders, Cold Start Idle, Hunting Idle
    By josh.c in forum Engine Bay
    Last Post: 14th March 2013, 4:02 PM
  3. hunting idle and really high idle
    By vanilla gorilla in forum Engine Bay
    Last Post: 22nd October 2012, 1:00 AM
  4. very weird idle problem
    By ricickles in forum Engine Bay
    Last Post: 10th August 2009, 12:59 PM
  5. weird mpg
    By billinjah in forum Engine Bay
    Last Post: 21st April 2005, 7:51 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
