Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Stiff accelerator pedal
  1. #1
    Enthusiast
    Join Date
    10th January 2003
    Location
    West Midlands
    Posts
    270
    Another question for you all (i'm full of 'em!)
    My accelerator pedal seems really stiff. To the point that when i change gear and take my foot of the pedal the revs are still high. I've had look underneath the pedals but part of the dash is in the way so i cannot see. Anybody had similar problem.
    Its also started to squeek when I accelerate. Add this to my brakes squeeling and the interior rattling when i go over bumps of almost got a band together! I should record it and release it as a dance track! Top 10 hit me thinks
    Old skool was da best skool
  2. #2
    Super Moderator CazzaVR's Avatar
    Join Date
    6th December 2002
    Location
    Wotton-under-Edge, Glos
    Posts
    7,463
    My accelerator pedal is very squeeky too- haven't had time to have a proper look at it yet- sure it just needs a dab of 3 in 1 or something (hopefully!).
    'ave it!
    Corrado Club of Great Britain
    Gone, but not forgotten: Mystic Blue VR6 Storm
    Now: Avus Silver Audi S3 :: 1.8 20v Turbo :: BAM :: Recaro Leathers :: Bose :: Badger 5 v2 TIP :: Forge 007p :: 18" RSTT
    Gallery
    "Look Sir, Dubs,"
  3. #3
    Newbie
    Join Date
    18th December 2002
    Location
    Hampshire
    Posts
    75
    i had a stiff accelerator when i bought my c, and eventually took off the cable and found it needed greasing up but then found the cabling was frayed so its easier to get another. so take out the cable first its a 5 min job and check how free it is, then the pedal?
  4. #4
    Enthusiast
    Join Date
    10th January 2003
    Location
    West Midlands
    Posts
    270
    How is it attached to the pedal??? Cannot see.
  5. #5
    Administrator
    Join Date
    8th November 2002
    Location
    Coventry
    Posts
    21,004
    My accelerator pedal is a bit squeaky too.. must get that looked at!
    When I first bought mine, had the same problem with the pedal being really stiff. A friend disconnected the throttle cable and ran a little WD40 all the way down it.. sorted the problem.
    Its also worth noting that the throttle cable gets quite slack if it hasnt been tightened up in a long time - mine was slack to the point of not actually opening the throttle the whole way. Tightened it up and it gave the car a noticable amount of extra punch
    | 1995 Corrado 2.9 VR6 (Classic Green) | 2013 Ford Fiesta ST-2 (Race Red) |
    | Old Corrado's :- Corrado 2.0 16v (pic) | Corrado G60 (pic) | Corrado 2.0 16v (pic) |
  6. #6
    I am 90% sure WD40 dissolves grease or says something to that effect on the tin, it frees stuff up but evaporates and leaves a mild coating or something, so you need to re grease what you use it on. I would use a little 3in1 oil or something.
    I could be talking rubbish, but dont have an english WD40 tin to hand and my spanish anit that good. Someone check and tell me i wrong please!!
    http://upload.the-corrado.net/files/44/home_sm.jpg
    |Present Motor: Audi A4 Avant 2.0T FSI Quattro S-Line|
    |Previously: SEAT LEON FR TDI|German Spec 92 G60 JET LHD, |Mk2 Golf Cab|mk2 Fiesta 1.4s|
  7. #7
    Newbie
    Join Date
    18th December 2002
    Location
    Hampshire
    Posts
    75
    cant remember exactly how the cable is fixed on but i think its just a loop or just a fixing of some sort. put some wd40 down it first and make sure its really loose then grease it. make sure theres no frays on it though as you dont want the thing snapping on you.
  8. #8
    CF God! VR6's Avatar
    Join Date
    8th November 2002
    Location
    The Gates of Hell
    Posts
    10,624
    Don't use just WD40 - it acts as a degreasant and will eventually dry out.
    Best thing is something simple like engine oil or 3-in-one.
  9. #9
    CF Nutter
    Join Date
    24th January 2003
    Location
    Kearsley, Manchester
    Posts
    1,374
    Dont bother guys - due to the way the cable routes it wears out the sleeve inside the cable at the bends - rather than mess about buy a new cable from VW (£15) and you will be amazed at the difference!!!!
    My 1999 Nissan 200sx S14a
    Much missed Corrado VR6 in Aqua Blue Pearl
    191bhp / 185lbft Torque
    CCGB Member #1686
    http://www.obsessivecardetailing.co.uk
  10. #10
    Enthusiast
    Join Date
    16th December 2002
    Location
    Kitchener, Canada
    Posts
    958
    buy a new cable!!!
    its true. amazing difference in the feel and satisfaction of the go pedal after you fix the cable.
    you have to take the lower dash panel above the pedal off. i took my seat out too since it takes 3 seconds in a vw. lie on your back with a flashlight and you can see that the cable is attatched with a loop of wire around a post that looks like a screw or nail with no thread. my cable also had a wire clip holding it in place that looked like a previous-owner quick fix that was a bitch to get off.
    its a 5 minute job other than fiddling with the hoop and the post..
    good luck. GET A NEW CABLE!!!!
Similar Threads
  1. ABS Light On, Stiff brake pedal
    By Wompa in forum Drivetrain
    Last Post: 19th March 2010, 1:56 PM
  2. Stiff accelerator pedal.
    By foster in forum Interior
    Last Post: 11th March 2008, 4:07 PM
  3. Loose accelerator pedal
    By Rustynuts in forum Interior
    Last Post: 29th October 2005, 4:13 PM
  4. Very firm accelerator pedal
    By Timo. in forum Archive
    Last Post: 15th July 2004, 6:20 AM
  5. Stiff pedal
    By J a m e s in forum Engine Bay
    Last Post: 30th October 2003, 3:18 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
