Results 1 to 7 of 7
Thread: VR6 running rough, video + pics included!
  1. #1
    Hey guys,
    I have an issue with my Corrado at the moment, I was driving the car and it was working perfectly fine, then it started to miss fire and run rough.
    Thought it was originally an ignition problem so have changed out the lead, plugs, dizzy and rotor arm but it still seems to be running badly.
    I have also cleaned out the ICV valve and this has not resolved the problem.
    I noticed an earthing point doesn’t seem to be connecting on the distributor; I have included a picture of this below:
    IMG_0225 by AvidJames, on Flickr
    IMG_0224 by AvidJames, on Flickr
    Also, does anyone know the name of the part the king lead connects to?
    IMG_0222 by AvidJames, on Flickr
    I recorded a short video to show you how it’s currently running!
    http://www.flickr.com/photos/avidjames/6960879700/
    Could this be a problem with the engine itself? There is no smoke on start up or when revving and no mayo under the oil cap.
    Any ideas where I should be looking next?
    Cheers,
    Duncan
  2. #2
    The part that the lead connects to its the ignition coil....
    Cant really make out whats rong with it.... But souds like a missfire. Check your sparkplugs if you changed the leads
    Sorry read again and you did change the sparkplugs....
    It might me something internal but would have to ear it live
    1994 Corrado G60 : 1989 Corrado G60 : 1994 Corrado VR6
    http://www.corrado-database.nl/index...w_user&id=3060
  3. #3
    ⋆⋆ CF Donator ⋆⋆ Stonejag's Avatar
    Join Date
    30th May 2011
    Location
    Harpenden, Herts
    Posts
    1,548
    Nice colour
    Try unplugging the MAF while it's running - if there's no change, there's the problem. Sounds more mechanical to me though?
    Stone
    '95 Blackberry Corrado VR6 auto - heated black leather, 312mm fronts and Mk4 rears, fixed steering column swap, US side marker repeaters, Roose Motorsport hose kit, Lupo wipers + custom aero rear wiper, Audioscape door pods, BMC CDA, 42draft inlet elbow, group buy poly mounts, R32 sump, decat + Magnex exhaust, dropped onto 16" TT Mini Comps
  4. #4
    thanks for the quick reply's i cleaned the icv again and refitted it and now its driving better than when i first got it! could the icv really make it misfire that badly? i only thought it made the rpm fluctuate and stall the engine? what mechanical faults should i be looking for? would it be best to get a compression test done on the engine just to be safe? or will vagcom throw up a mechanical fault if there is one? sorry for all the questions im just really worried its something major even though its running fine now
    ohh and thanks the colour's awesome! cant wait to get my da buffer out and give it a major detail
  5. #5
    Super Moderator CazzaVR's Avatar
    Join Date
    6th December 2002
    Location
    Wotton-under-Edge, Glos
    Posts
    7,463
    Yep, it can make it stall and splutter badly, especially when the foam from the damper box gets sucked into one of the pipes or the ISV itself!
    'ave it!
    Corrado Club of Great Britain
    Gone, but not forgotten: Mystic Blue VR6 Storm
    Now: Avus Silver Audi S3 :: 1.8 20v Turbo :: BAM :: Recaro Leathers :: Bose :: Badger 5 v2 TIP :: Forge 007p :: 18" RSTT
    Gallery
    "Look Sir, Dubs,"
  6. #6
    seems thats sorted then phew but where does that earth strap go to?
  7. #7
    ⋆⋆ CF Donator ⋆⋆ Harrier's Avatar
    Join Date
    1st July 2008
    Location
    Hampshire
    Posts
    822
    I think there originally would have been a metal surround around dissy cap.It plugs on there.Don't think you will have any problems without it.
Similar Threads
  1. Broken Schrick Manifold - pics included, any ideas?
    By ___Dubstar___ in forum Engine Bay
    Last Post: 5th August 2010, 7:44 PM
  2. VR6 Running rough as...
    By VR6Bella in forum Engine Bay
    Last Post: 7th March 2007, 2:56 PM
  3. Rough running
    By PJutla in forum Engine Bay
    Last Post: 29th June 2006, 9:12 AM
  4. VR running very very rough!!
    By DragonAttack in forum Engine Bay
    Last Post: 28th June 2006, 7:21 PM
  5. rough running vr
    By matt_corradovr6 in forum Engine Bay
    Last Post: 7th January 2005, 10:52 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
