Piper666
Heater only works on 4
I know this is a common problem and probably already a post up but it one of the most annoying things ever!
Is it just a case of fitting a new resistor??
Can anyone help? Thanks
yeah it gives me the hump. i recently fixed mine only to discover that the contact on the dials are not good so i can only get 3 and 4. and maybe 2 if i wiggle it about a bit. so its either boiling or freezing in my car. :lol:
I did the thermal resistor fix on mine, and found that speed 1 still didn't work. 2 mins with a pair of point nose pliers did the trick, just "persuade" the contact out a little...
If you have early interior I have a brand new switch you can have for £7 delivered?
common problem, it can be your resistor or the fan switch.......if you can wiggle it and it works then its the fan switch. ......if it doesn't most like resistor...........if its dead all together..........get all including a motor ;)
