dirtytorque
16v coolant sensor
hello.
Can someone point out which sensor is the colant sensor out of the 4 sensors aound the coolant flange.
I know the one bottom right is a coolant switch i.e off or on.
So which of the other three is a proper coolant sender?
Thanks in advance.
they all are?
they look the same as the 3 on a valver head, single connector, black top, in which case they are all the same part number, just provide a signal to different sytems, gauge, ECU, idle control unit.
  davidwort said:
they all are?
It is a valver head and they came with it in those positions so many thanks.
top left in pic, i think......well its the temp senor anyway, and they are all the size part number mate
