awigman
Drivers Window wont go down
Hopefully just a quick question. My drivers window has suddenly stopped working. The passenger one is fine its just the drivers. It makes the clicking noise when i press the button but nothing happens. anyone know what this could be?
Thanks
It sounds like either a wiring fault, or a faulty motor. Check the wiring between the A post and door as there cam often be a broken wire at this point where the wiring is continually being stressed. If the wiring is ok then you it is likely that the motor has a fault. This should get your fault finding process started, but this detail is far from complete, allways better if one has the car in front of you in such issues as this.
