Elliot N 10 Posted January 9, 2013 Hi, I am having an engine rebuild done soon and I need to find piston rings and big end bearings to fit! I have seen some KS brand big end bearings http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=251206897773&ssPageName=ADME:X:RTQ:GB:1123 and some RIC brand Japan made piston rings http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=271088677403&ssPageName=ADME:X:eRTM:GB:1123 my question is has anyone used these before? would you recommend them and if not where could I find the OE parts without going direct to the stealers! thanks. Quote Share this post Link to post Share on other sites
fla 9 Posted January 9, 2013 i've used KS big end bearings - they're fine. Can comment on the rings though. Why such a major overhaul though? Are you burning oil? Quote Share this post Link to post Share on other sites
Elliot N 10 Posted January 9, 2013 i've used KS big end bearings - they're fine. Can comment on the rings though. Why such a major overhaul though? Are you burning oil? Low compression , burning oil need to get it rebuilt Quote Share this post Link to post Share on other sites
pbradley98 0 Posted January 10, 2013 Hi, If you're considering a rebuild it's worth checking if cylinders 1 and 6 have any ovalisation, as they are prone to this which contributes to the oil consumption and I'm not convinced new pistons / rings will cure this (others may be able to give more definitive advice on this!) If you're doing this may be worth considering a rebore and oversized pistons. Cheers Phil Quote Share this post Link to post Share on other sites
Elliot N 10 Posted January 10, 2013 Hi! the engine is a 1.8 16v 4 cylinder so don't have the worry of 6 cylinders haha, yeah as soon as the block is stripped apart its going to be taken to the machine shop and honed, tolerances checked then machine washed and painted, the ovalization was the concern that I did have though which is why I want it to be done properly, the original engines compression test results were 140, 135, 142, 100 on a dry test, and on a wet test cylinder #4 jumped up from 100 to 140 (Y) Quote Share this post Link to post Share on other sites
pbradley98 0 Posted January 11, 2013 Yep had jumped the gun assuming it was a vr! Hope it all goes well... Quote Share this post Link to post Share on other sites
