Kevin Bacon 5 Posted May 26, 2004 OK, everytime I drive down my daily country road route, the parcel shelf jumps up and down over the bumps, even pretty minor ones. It's irritating as I can feel it through the floor and obviously hear it, which sounds like the exhaust knocking on the axle/strut bolts but it isn't, it's the damn shelf - which has speakers on it btw. What I want to know is how you guys keep your shelves still? The foam blocks are present on my tailgate and it's clipped into the holders by the seat fully. For the time being I've screwed the shelf to the supports and it's worked, but it's impractical when shopping etc. The standard way of keeping the shelf still isn't working, so have any you got any tips for keeping that spring board still? Cheers K Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 26, 2004 Foam blocks?! :? I think I found out why my parcel shelf rattles like a barsteward. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 26, 2004 Yep, lift the tailgate or look in the rear view mirror and you should see a large black foam block at each end, glued to the tailgate. These are *supposed* to press down on the tailgate end of the parcel shelf, but aren't very effective. K Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 26, 2004 No doubt you have to buy a whole tailgate from VW to get these bits! :lol: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted May 26, 2004 Knowing VW you probably have to buy an ENTIRE car :lol: :lol: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 26, 2004 Am I the only person with this problem? Can't believe that for one minute........ Maybe I'm the only person that cares about it, LOL! K Quote Share this post Link to post Share on other sites
G60 0 Posted May 26, 2004 if you can't stop the rattling, maybe put some rubber material on the contact surfaces to help with the noise and vibrations in the floor? Quote Share this post Link to post Share on other sites
VR6 0 Posted May 26, 2004 On a variation of the nodding dog theme, just get a pretty laydee to lie down on the shelf whilst you are driving. HTH Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted May 26, 2004 The foam blocks can be obtained from VW. Quote Share this post Link to post Share on other sites
Joe M 0 Posted May 26, 2004 Velcro on the corners where it sits on the plastic side bits. (Techy description.) 8) One of the first things I done to my vr after having the same prob in my old 16v. Quote Share this post Link to post Share on other sites
Henny 0 Posted May 26, 2004 yup I used sticky back velcro on my first 'rado... 8) Only thing is that it makes a ripping noise when you open the boot which can make people a bit worried the first time they open your boot for you! :lol: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 30, 2004 So long as it isn't your trousers making a ripping noise :lol: Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 30, 2004 I just noticed there are no foam blocks on my C either :( but wasn't causing me a problem. Now I don't like having something missing if it should be there so I'll put some on, I might even notice a difference. Quote Share this post Link to post Share on other sites
STORM 2 0 Posted May 30, 2004 look at where the rubber stops of the parcel shelf slot into the plastic slots of the plastic side panels (rear speaker units) these are usually broken off and you will find that the shelf will move slightly up and down if you grab it and try to move it. Drastic (+expensive) solution would be to replace these rear side panels in order to get unbroken slots, but I suppose black tape wrapped around the rubber and then getting a tight fit into the slots may work. I haven't tried it yet but will get round to it soon...... Quote Share this post Link to post Share on other sites
fla 9 Posted February 25, 2009 anyone else tried any good solutions here? Kev did you come with anything? Dont really fancy the velcro 'ripping', tbh. Quote Share this post Link to post Share on other sites
Philmo 0 Posted February 25, 2009 I've got some extra thick black foam [8mm approx] which makes excellent replacements for the tired OEM blocks which fell off. Quote Share this post Link to post Share on other sites
KADVR6 0 Posted February 25, 2009 i used some little but very powerfull magnets to hold my shelf's in place, worked great even when i had a stealth shelf fitted. Quote Share this post Link to post Share on other sites
The_Dude 0 Posted February 25, 2009 i used some little but very powerfull magnets to hold my shelf's in place, worked great even when i had a stealth shelf fitted. No thanks, I've seen that thread in off-topic. :gag: Quote Share this post Link to post Share on other sites
KADVR6 0 Posted February 25, 2009 i used some little but very powerfull magnets to hold my shelf's in place, worked great even when i had a stealth shelf fitted. No thanks, I've seen that thread in off-topic. :gag: ???? Quote Share this post Link to post Share on other sites
The_Dude 0 Posted February 25, 2009 http://www.the-corrado.net/.archive/forum/viewtopic.php?f=10&t=77291 Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 25, 2009 the early and late shelves are different aren't they? the early one on my 16v never moves or makes a noise even when I had stupidly firm dampers on the back, I wonder what's going on then, does the late shelf not have the raised shape on the edge where the foam buffers touch :shrug: or are you guys all supporting wopping great speakers in the shelves, cutting holes in genuine corrado shelf :nono: Quote Share this post Link to post Share on other sites
fla 9 Posted February 25, 2009 I have standard shocks on mine plus i'll have the speedies back on so should be fairly soft. My shelf also has those raised parts on them, just no rubber blocks on the boot lid. As Pianowire mentioned you feel the rumble right through the chassis and me being paranoid about creaks rattles and rumbles, kept thinking this was the exhaust. Quote Share this post Link to post Share on other sites
andy 0 Posted February 25, 2009 I have this problem, with an mdf shelf though, is yours the original Kev? I was thinking of reverting to that... Quote Share this post Link to post Share on other sites
