Yabble Dabble 0 Posted May 21, 2016 (edited) Looking for a replacement Rocker Cover with Groove to take Gasket - Back in Sept 2015 got a Rocker Cover installed to replace Boomerang shaped version. Understand that the replacement was flush and not grooved. Worked well for a bit then started slow trickle of oil. Need to keep topping oil up and want to replace with flat (non-boomerang), grooved correct cover during June half term. Thanks for any help. Edited May 21, 2016 by Yabble Dabble Quote Share this post Link to post Share on other sites
gotvach 10 Posted May 24, 2016 According to VW Parts Vortex 021 103 475 G was replaced by 021 103 475 M. Both parts are listed at vagpart.com (item 17). Might help with your ongoing search. Assuming 021 103 475 M has the groove you're after I found a used one on auction. http://www.ebay.com/itm/Volkswagen-Golf-Passat-oem-Parts-021103475M-Engine-Valve-cover-6-CYLINDER-/121795710076 Interestingly listed as Golf/Passat so you would think the cover might be easier to find. Quote Share this post Link to post Share on other sites
gotvach 10 Posted May 24, 2016 Seems there are two items on ebay right now ... search term 021103475G. Any good? Guess you could ask them about the groove :) Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 24, 2016 I've got a few of these will check tomorrow for you Quote Share this post Link to post Share on other sites
