Miikeyboy 10 Posted August 16, 2017 Has anyone fitted any of the new front brake shields yet?. I'm having an issue where one end is pressing againt the abs rotor(see pic) the rotor can't go any further in, so is it just a case of bending the shields or shimming them?. It's the same on both uprights. Cheers Sent from my SM-G955F using Tapatalk Quote Share this post Link to post Share on other sites
Cressa 39 Posted August 16, 2017 That's the only photo I have of mine. ...doesn't show much unfortunately. I'm sure someone will have a better pic Cressa Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted August 16, 2017 And they fitted ok with no touching? Sent from my SM-G955F using Tapatalk Quote Share this post Link to post Share on other sites
Cressa 39 Posted August 16, 2017 I have one fitted. Contact easypops on here or search for a thread on this. He was the guinea-pig for this and put pictures up for the trial fitment of them Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted August 16, 2017 Thanks just checked and it looks like the part that is pressing against the rotor is the wrong side of it, but sure how that has happened it some adjustment is needed Sent from my SM-G955F using Tapatalk Quote Share this post Link to post Share on other sites
easypops 6 Posted August 16, 2017 I was indeed the guinea pig, I think my pictures will have gone due to the photobucket issue, I'll try and add them again here Quote Share this post Link to post Share on other sites
easypops 6 Posted August 16, 2017 Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
easypops 6 Posted August 16, 2017 This shows that bit in the correct place Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted August 16, 2017 I think what has happened is I have pushed my hub too far so it is too close to the knuckle. The rotar also rubs against the sensor as well as the shield. I assumed you pushed it in until it stopped,but maybe not? Can anyone advise me on this? Sent from my SM-G955F using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted August 16, 2017 See i have put it the right side now but it is squashed up against the rotor. I can pull the rotor out a bit but wont it mive back in again? Sent from my SM-G955F using Tapatalk Quote Share this post Link to post Share on other sites
easypops 6 Posted August 16, 2017 I'm not really sure mate? Is the bearing all the way in? As the hub can only go in so far(I think?) I'll take a picture of the back Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted August 16, 2017 Sent from my SM-G955F using Tapatalk Quote Share this post Link to post Share on other sites
annavr6 10 Posted August 17, 2017 Hi Just to add, out of all the sets sold so far we have had no issues reported or returns. I am (have fitted 1 side) fitting a set myself but my car is not ABS as its on a mk2 with a Corrado G60 brake set up. Will keep an eye on this to see the outcome, i hope you get sorted Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted August 17, 2017 Hi, its definately not a problem with the shields they are fine, it's down to how my hubs are fitting in the bearing Sent from my SM-G955F using Tapatalk Quote Share this post Link to post Share on other sites
