michaelbailey 10 Posted September 28, 2017 Hi guys, Abs light is on and what i can tell you is that it was intermittent but now always on. Used to put the brakes hard on when you slightly pushed the pedal and then the light would go on and the problem would stop but obviouslly no abs. The light flashes as the pump cycles and the pedal depresses as you start engine and theres like a tick on the pedal as you put ignition on after about 3 seconds. Had a bit of coolant come out of expansion tank as been fighting a battle with that but with that now sorted want to get this fixed as mot is coming up. Mank thanks! P.s dont know anyone with a vagcom. 95 vr6 Quote Share this post Link to post Share on other sites
Dox 20 Posted September 28, 2017 Location? Pedal sensor would be my guess Quote Share this post Link to post Share on other sites
michaelbailey 10 Posted September 28, 2017 Im stockport. South manchester. Is there anyway to check the pedal sensor? Quote Share this post Link to post Share on other sites
Dox 20 Posted September 28, 2017 I'm near Nantwich Cheshire, bit of a trek but if you're ever down this way etc Quote Share this post Link to post Share on other sites
michaelbailey 10 Posted September 28, 2017 Well might be worth the hour drive if you can provide any assistance. Obviously rewards are offered. Very ****ing busy at the minute but with the mot coming up i need to get something done Quote Share this post Link to post Share on other sites
Philly-R6 0 Posted September 28, 2017 Michael, I have VCDS and am only in Hazel Grove - if that helps you? (Mind you, negotiating the A6 it may be quicker to go to Nantwich!) Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted September 29, 2017 I am in Liverpool (junction 5 M62) if you let me know l can get hold of a sanp on reader ,have used it on my 1993 Corrado and work well Quote Share this post Link to post Share on other sites
