poll250 0 Posted November 16, 2018 (edited) I've had this car for nearly 12 years and have taken it from Standard, to what I'd say was one of the best Corrado's in the country. Full spec below but basically it's a VRT with LSD, Traction Control, Big brakes etc. No expense was spared in this build and I have a folder full of a scary amount of receipts to prove it! Although I still love it, it's sat on my parents driveway for the last few years, getting driven up and down the road on a monthly basis, but it really is time I moved on and let it go to a new home. Specs are as follows; M Reg Aqua Blue Pearl Corrado VR6 Currently SORN 160k 380Bhp, 375 lb/ft Exterior Paint is pretty good for a 24 yr old car, but does need some polishing work + the usual small dents and scrapes to be expected. Clear Oval repeater 50mm Spliter Red film tinted Lights Lupo Wipers Engine bay Stealth Racing Stage 1+ Turbo conversion: T60/1 Turbo with Garrett internals,FMIC, chrome pipework, manual adjustable Forge recirc valve, later CP ecu and 4" MAF housing. Rebuilt VR engine fitted approx 10k ago. 8.5:1 Headspacer, Autotech 262 cams, ARP Head and Rod bolts, Bosch Green top Injectors All new engine sensors, thermo housing etc Dubpower Ht leads Complete Custom 2.5 inch Stainless exhaust system built at Stealth, no cat is fitted, doesn't sound too boomy at all.New rubber hangers fitted Vibratechnics Rear Engine and Gearbox mount, BlackForestIndustries Front Mount. Holds everything steady with no excess vibration from cold. Wallbro in tank fuel pump 13 row Mocal Oil cooler, new standard heat exchanger and pipes with longer bolt New Genuine Radiator + elbow (one of the last left of each) Uprated Headlight Loom + Osram Nightbreaker Bulbs Drivetrain Racelogic Traction Control (with Launch Control) Really helps get the power down and eliminates wheelspin very subtly. Fixed Steering column with the last fixed cowling available! New wheel bearings front and rear,r32 wishbone bushes, Ball joints, Track Rod ends, Subframe bushes,Powerflex rear axle bushes Gearbox rebuilt by Riccardo in Leamington (they make the gearbox for Mclaren Mp12-4cs) and a Wavetrac LSD was fitted, new seals and bearings where needed. Lightened and balanced Flywheel New Helix clutch with heavy duty release arm Audi S3 shift tower, TTweight and cables, mounted into OE Polo housing. Fits perfectly and gearshift is as good as a modern car. Suspension/Brakes 17x7.5" Genuine BBS RC 323 alloys with Kumho KU tyres. Arguably one of the best wheels on a Corrado 10mm H&R hubcentric spacers front and rear Weitec Hicon GT height adjustable coil overs. Front: Porsche Boxster Brembo front callipers with standard VAG 312mm discs, Ferodo DS2500 pads. Pedal feel is really good and stopping power is great! Rear: MKIV Golf rear Callipers with standard discs and Pagid pads Goodridge raided front and rear lines Weitec rear ARB Interior Recondtioned Standard Cream leather seats +doorcards Black A,B & C pillars Headunit with rear aux in Panasonic speakers and tweeters 320mm Momo Race steering wheel DDI backlit dials and Reverse LCD Red LEDs in switches New Headlight switch New Window rollers Chrome door pulls and pins Silent coat sound deadening in doors pods, rears also filled with bubble wrap. Doors close with a nice thud. EL Sheet Backlit heater controls red/blue colouring Audi S-line Gearknob Bad points: Wheels could do with a refurb Needs 4x new tyres Heater control direction knob is broken, currently set on windscreen/face (may also fix myself) Paint bubbles under inner arches Small coolant hose leak The car 'did' start and drive fine up to about 30mph, but has since cut out and won't start. I just don't have the time/will to look into it, and it's sad to see it sit there for another summer. Price – £6500 takes it away. Quick video of it running Thanks, Andrew Edited July 15, 2019 by poll250 Back up for sale! Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted November 16, 2018 Wow mate long time mate nice car this glws Quote Share this post Link to post Share on other sites
Zebby 10 Posted November 26, 2018 Perfect spec!!!! Really wish I had the money! best of luck with the sale! Quote Share this post Link to post Share on other sites
coullstar 0 Posted November 30, 2018 Probably the only thing that would tempt me back into one. Quote Share this post Link to post Share on other sites
poll250 0 Posted December 3, 2018 Probably the only thing that would tempt me back into one. Open to offers mate! Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 3, 2018 RS4, 996 and young family means zero cash! RS4 + cash my way? Lol Quote Share this post Link to post Share on other sites
poll250 0 Posted December 4, 2018 RS4, 996 and young family means zero cash! RS4 + cash my way? Lol Tempting but I also have a C63 I don't drive nearly enough! Quote Share this post Link to post Share on other sites
dubbrothers 10 Posted December 22, 2018 (edited) Hi mate please tedt your number *Number removed* and I'll text a few questions if ok *Mod edit* please exchange numbers via PM. Edited December 30, 2018 by CazzaVR Quote Share this post Link to post Share on other sites
Mrbaldhead 10 Posted December 29, 2018 Am I blind or is there no indication of price? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted December 30, 2018 Andrew, could you please add a price. Ta :) Quote Share this post Link to post Share on other sites
fla 8 Posted December 30, 2018 Obd2 plus climatronic and you've got the best possible corrado. Superb spec, which deserves a good buyer Quote Share this post Link to post Share on other sites
poll250 0 Posted December 31, 2018 SOLD: Deposit Taken! Quote Share this post Link to post Share on other sites
poll250 0 Posted July 15, 2019 Bump - Back up for sale. It started fine and strong first turn, and was driving fine up to 2500rpm, but started spluttering above that. I ran it up to temp on the driveway ready for a longer drive and the engine cut out. It won't restart (I've tried a different battery and cleaning terminals). Sadly, I don't have the time to look into it anymore, but would like to see it go to a good home this summer, rather than sitting on the driveway for another year. Quote Share this post Link to post Share on other sites
fla 8 Posted July 15, 2019 109 relay and crank sensor ok? Also, I recently traced a no start issue to a faulty cable to the starter solenoid. Yours is SUCH a great car its a shame to hear about these sorts of issues, i'm sure its something simple.. Quote Share this post Link to post Share on other sites
V-spec 10 Posted July 22, 2019 Just checking if you received my last pm reply from Sat? Quote Share this post Link to post Share on other sites
poll250 0 Posted July 22, 2019 Just checking if you received my last pm reply from Sat? Hi Andy, received & replied. Quote Share this post Link to post Share on other sites
poll250 0 Posted July 23, 2019 DEPOSIT TAKEN :cheers: Quote Share this post Link to post Share on other sites
fla 8 Posted July 23, 2019 Glad to hear it - someone is getting an absolutely stunning Corrado Quote Share this post Link to post Share on other sites
