carrots
hog rings or cable ties
ive got some new bolster foam for my seat base.before I start the job I want to see whats best to use to re attach the cloth to the frame.hog rings (I would have to buy rings and tool) or small cable ties.cheers
I'm not sure you need to buy new rings and a tool.
When I replaced my seat foam, I used pliers to undo and refit the hog rings. Just take your time - we are supposed to enjoy these challenges!
Yeah I used a set of needle nosed pliers, fed them through the rings then opened them up to remove, then just a normal set of pliers to close them back up again. So long as you don't open them right up, they're perfectly re-usable.
I can't directly help but where did you source seat foam? I can feel springs/metal after sitting in my drivers seat for an hour..
