victorpolanco 10 Posted February 10, 2019 I have a 1993 vr6 and I have a blown head gasket but it has upgraded cams and a few other mods currently. I’m Not sure if it caused any damage to the cylinder heads (there are some noises coming from the engine) so to save time and stress I’m thinking of just getting a new engine. What’s the best and most updated/reliable engine I can put in it or should I just try and take my current one apart and repair? Thanks! Quote Share this post Link to post Share on other sites
Keyo 49 Posted February 10, 2019 (edited) victorpolanco said: I have a 1993 vr6 and I have a blown head gasket but it has upgraded cams and a few other mods currently. I’m Not sure if it caused any damage to the cylinder heads (there are some noises coming from the engine) so to save time and stress I’m thinking of just getting a new engine. What’s the best and most updated/reliable engine I can put in it or should I just try and take my current one apart and repair? Thanks! If it was up to me I would keep the original engine and rebiuld it better the devil you know then dont, if your near Banbury go and have a chat with Vince form Stealth Racing he is an expert and can advise you on Corrado engine build. It really is your choice. Suprisngly there is a 2.9 engine block for sale on ebay https://www.ebay.co.uk/itm/Vw-VR6-Engine-2-9-AAA/202586091768?hash=item2f2b1270f8:g:fbYAAOSwjmRcVhEL:rk:3:pf:0 Edited February 10, 2019 by Keyo Quote Share this post Link to post Share on other sites
Dox 28 Posted February 10, 2019 AAA is 2.8. I suspect the OP is overseas anyway Quote Share this post Link to post Share on other sites
victorpolanco 10 Posted February 10, 2019 I’m leaning towards just getting a new engine because of the ticking noises I’ve been hearing and because I’ve had overheating issues for a while. I’m thinking a rebuild would be a lot more expensive. Unfortunately I’m in the states or I would talk to him, thanks for your input Quote Share this post Link to post Share on other sites
Keyo 49 Posted February 10, 2019 If your going down that route then Im sure some of the lads on here can help you. Dox didnt see the AAA well spotted. Quote Share this post Link to post Share on other sites
victorpolanco 10 Posted February 10, 2019 Keyo said: If your going down that route then Im sure some of the lads on here can help you. Dox didnt see the AAA well spotted. Is the aaa engine the original one that came in the Corrado’s or is that just a different one that would be easy to install Quote Share this post Link to post Share on other sites
Keyo 49 Posted February 10, 2019 (edited) In Europe the AAA is the 2.8 VR6 engine fitted to the golf. Jetta, Passat, I believe this is the same engine they fitted in the Corrado SLC in the USA I think, in Europe the Corrado VR6 came with a ABV 2.9 engine block. If you can confirm your engine is AAA 2.8 then you should get a block in the USA easily. This is from Wiki The second was the twelve valve VR6 engine, which came in two variants: a 2.8 litre 179 bhp (133 kW; 181 PS) model for the United States and Canadian markets, and a 2,861 cc (2.9 L; 174.6 cu in) producing 190 PS (187 bhp; 140 kW) at 5,800 rpm and 245 N⋅m (181 lbf⋅ft) at 4,200 rpm of torque version for the European market, fuel feed by Bosch Motronic 2.7 fuel injection.[6] In the United States, the model VR6 was marketed as the Corrado SLC (sport luxury coupe). Edited February 10, 2019 by Keyo Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted February 11, 2019 Hi, I've got an ultra low miles 2.9 ABV vr half engine left over. It's only run 19.000km's.. Only got the block, pistons, crank, sump rods etc as head was sold ages ago. Let me know if your interested. cheers-Andrew Quote Share this post Link to post Share on other sites
swiftkid 1 Posted February 11, 2019 If the head gasket has gone and you are not driving it why not just pull the head off and take a look. If it's cracked the block or done some other severe damage then you've had your decision made for you. Otherwise maybe decide what the future holds for your rado, if you've added cams and fancy more power it's a perfect opportunity to look at turbo and I'd imagine it's bucket loads cheaper for parts over there than here. Personally I'd stick with a 6 pot, could consider 24v but have a good read up on what's involved. The power is good but I do miss the VR6 engine Quote Share this post Link to post Share on other sites
karmannski 0 Posted February 11, 2019 Swiftkid is right, to take the head off it is only 2h job if you know what you are doing. It can't be that bad. But If you swap. look for another AAA donor. Keep it simple + have some spare parts of your old one. Quote Share this post Link to post Share on other sites
