Pjmur 10 Posted February 26, 2019 Hi. I've 17 ' bbs on car ,but not happy with how far out beyond the wheel arches they are with original vr6 brake set up - needs 23mm spacer so could clear spaces . Want them flush with arches if possible . So question is pls - what would be recommended as replacement set up to achieve this . Cheers 👍 Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 26, 2019 New wheels..... If they're protruding from the arch but you need 23mm spacers just to clear standard brakes, you have the wrong offset wheels. 17" wheels with 205/40 tyres require an offset of around ET35. What's the offset of the wheels you have on now? Quote Share this post Link to post Share on other sites
Pjmur 10 Posted February 26, 2019 Hi. I'm.not quite sure ,must check that out . They 're perfect on rear ,just front is the issue . Will check and revert back . Tku Quote Share this post Link to post Share on other sites
Dox 18 Posted February 26, 2019 Post a pic of the brakes, the car may have non standard brakes currently? Quote Share this post Link to post Share on other sites
Pjmur 10 Posted February 26, 2019 Will do . Tomorrow sometime guys. Tks again Quote Share this post Link to post Share on other sites
Pjmur 10 Posted February 27, 2019 Et 30 is offset ,picture yet to do ,just not at present with the car .apologies . Quote Share this post Link to post Share on other sites
