ger040 3 Posted June 17, 2020 after a recent clutch master cylinder replacement i have decided to give my car a complete brake fluid change, my last mot the tester said that the rear brakes were not operating to their required efficiency but as the car had recent disc and caliper replacement he let it pass (just) so today using a pressure bleeder all was going well until i got to the offside rear - plenty of air bubbles however some 4 litres and several hours later still getting micro bubbles does 4 litres seem excessive - had to stop as i have run out of fluid. how much fluid should it roughly take? Quote Share this post Link to post Share on other sites
Dox 23 Posted June 17, 2020 Are you vacuum bleeding? Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 18, 2020 I’ve just done my rear calliper upgrade and used about the same amount maybe a bit more. Drivers rear seemed to have more air in it too. Used a pressure bleeder that uses 20 psi out of a tyre. Quote Share this post Link to post Share on other sites
ger040 3 Posted June 18, 2020 5 hours ago, Dox said: Are you vacuum bleeding? using a sealy 820 clutch and brake bleeding kit Has a internal hand pump i boost to 1-1,5 bar Quote Share this post Link to post Share on other sites
ger040 3 Posted June 18, 2020 (edited) 2 hours ago, 1xshaunx1 said: I’ve just done my rear calliper upgrade and used about the same amount maybe a bit more. Drivers rear seemed to have more air in it too. Used a pressure bleeder that uses 20 psi out of a tyre. seems to taking a lot of time and wasting a lot of fluid yes its the drivers side rear too Edited June 18, 2020 by ger040 Quote Share this post Link to post Share on other sites
Dox 23 Posted June 18, 2020 39 minutes ago, ger040 said: using a sealy 820 clutch and brake bleeding kit Has a internal hand pump i boost to 1-1,5 bar I’m on my second one of those, on the original nut that holds the pump to the reservoir cracked. whats the pedal like? Quote Share this post Link to post Share on other sites
ger040 3 Posted June 18, 2020 1 hour ago, Dox said: I’m on my second one of those, on the original nut that holds the pump to the reservoir cracked. whats the pedal like? pedal feels good always has. i will give it another hour this evening see how it goes Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 18, 2020 (edited) I've got one of those too. Was hoping it would be better than an e-z bleed. 😬 Will be using it for the first time when I get my MC back in the next couple of weeks hopefully. Might be worth checking the fluid in the reservoir, when I used a e-z bleed last time, it was introducing a lot of air into the fluid at the reservoir side. Thought it could have been to do with either too high pressure, or a leak so sucking in air somewhere within the pressure side. Edited June 18, 2020 by seanl82 Quote Share this post Link to post Share on other sites
ger040 3 Posted June 18, 2020 4 hours ago, seanl82 said: I've got one of those too. Was hoping it would be better than an e-z bleed. 😬 Will be using it for the first time when I get my MC back in the next couple of weeks hopefully. Might be worth checking the fluid in the reservoir, when I used a e-z bleed last time, it was introducing a lot of air into the fluid at the reservoir side. Thought it could have been to do with either too high pressure, or a leak so sucking in air somewhere within the pressure side. strange its only the rear drivers side the reservoir is 28 years old and is cloudy so cant really see things inside. Quote Share this post Link to post Share on other sites
Dox 23 Posted June 18, 2020 You could try and wipe a little grease around the nipple to prevent air ingress via the nipples thread - this can happen when vacuum bleeding (drawing in air instead of sucking through the fluid). I've never heard of the same via pressure bleeding but you never know (we use compressed air through venturis at work to create vacuum - a bit like the theory of a carburettor. Quote Share this post Link to post Share on other sites
ger040 3 Posted June 18, 2020 i will try it and see Quote Share this post Link to post Share on other sites
ger040 3 Posted June 18, 2020 3 hours ago, Dox said: You could try and wipe a little grease around the nipple to prevent air ingress via the nipples thread - this can happen when vacuum bleeding (drawing in air instead of sucking through the fluid). I've never heard of the same via pressure bleeding but you never know (we use compressed air through venturis at work to create vacuum - a bit like the theory of a carburettor. Cant believe it DOX, Took the bleed nipple completely out put a few turns of PTFE tape reinstalled a hey presto NO BUBBLES as you say vacuum yes positive pressure no THANKS Quote Share this post Link to post Share on other sites
