colinstubbs 0 Posted March 5, 2010 Replaced all the vacuum rubber hosing and the throttle body rubber boot (£50!). She didn't want to fire up but had a fiddle with the vacuum capsule thingie plug on the air metering head and it started :clap: . Not gone for a drive yet, should cure the gentle kangarooing on lift off!! Fingles-crossed :lol: Edit - No it hasn't but the shagged CV joints (multiple methinks) prob ain't helping none. :( Quote Share this post Link to post Share on other sites
G60_Marc 0 Posted March 9, 2010 Removed stock o2 sensor from de-cat pipe and fitted a bosch 4.2 wideband sensor in its place. Wired in wideband controller and gauge. Connected simulated narrowband output from controller to the ecu. Set co pot to roughly 14.7 at idle when the engine is warm. Glad to say that the car seems to be fueling perfectly. Next. :salute: Quote Share this post Link to post Share on other sites
delfinis38 1 Posted March 10, 2010 got the welder out to put a splodge of weld on the CAT shield. in prep for the mot next week. Quote Share this post Link to post Share on other sites
Mawrick 0 Posted March 12, 2010 Got a guy to tear apart the alternator so I can get it powdercoated....:) Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 13, 2010 Put the rear lights on i bought of Bristolbaron,three were straight forward,the fourth needed a bit of adjustment ! After all of that,not sure if i like them ! Then put on my NEW 90amp alternator i bought from the stealers. :cuckoo: Quote Share this post Link to post Share on other sites
Wullie 1 Posted March 13, 2010 Washed it. It's white!! Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted March 13, 2010 Repaired the passenger door handle were the door lock had snapped off inside the door. Lucky I'm a horder of bits, as I had a spare handle/lock. Quote Share this post Link to post Share on other sites
holeinmk1 0 Posted March 14, 2010 Gave mine her first wash and polish since buying her, then took her for a good run on the m60. Good times! :D Quote Share this post Link to post Share on other sites
lion 0 Posted March 14, 2010 fitted a moon roof updated front end (indecators and fogs) changed my rims porsche d90s to some deep dish keskins :) Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 14, 2010 Finally got round to fitting my vented brake arch liners, There's probably a proper name for them,but it escapes me ! :cuckoo: Quote Share this post Link to post Share on other sites
Toad 0 Posted March 14, 2010 Got the valver running and moved to the new house, and ordered a load of tools. Will order some parts for the valver in the week. :) Quote Share this post Link to post Share on other sites
vornwend 0 Posted March 14, 2010 Took my 80 year old mum to lunch in the Storm - took quite a while to get her in and out :nuts: Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted March 16, 2010 Decided that tomorrow I'd better change my iginition switch after having about 30 attempts to start it after a probable job interview failure. :( Luckily I was round the corner out of view! :lol: 8) Quote Share this post Link to post Share on other sites
too hot 0 Posted March 16, 2010 Decided going to get my finger out and get the Corrado on the road. Started today by putting the battery on a charge---------well its a start :lol: :lol: Quote Share this post Link to post Share on other sites
tandino 0 Posted March 16, 2010 Old Vr6 Engine & box out today.. New engine & box in tomorrow.... Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted March 17, 2010 Finished my stealth sub shelf and fitted it :) looks really good, almost OEM http://the-corrado.net/.archive/forum/viewtopic.php?f=6&t=90519 Quote Share this post Link to post Share on other sites
-Neil- 0 Posted March 17, 2010 spent 5 hours on the car, took all inlet pipes off and ISV off to clean them as car is stalling. washed, t-cut twice (bonnet took 4 t-cuts) then pollished, car is actually slightly shiny now! getting it clean for fast car show this weekend. Quote Share this post Link to post Share on other sites
MikLSP 0 Posted March 20, 2010 Bought it!! :-D Quote Share this post Link to post Share on other sites
Mawrick 0 Posted March 20, 2010 Bought it!! :-D Good for you! :) Have you posted pics?. Other than that I did (yeasterday) refit the brake caliper carriers, the "dust shields", and did some more cleaning of the gearbox........starting to closing in on refitting the rear beam, and getting that engine back in.........da*** I look forward to driving this thing for real after I bought it :) Quote Share this post Link to post Share on other sites
MikLSP 0 Posted March 20, 2010 Not yet I'm afraid but I will be doing once I'm actually back home and on a computer not a phone. I bought the "ABT" one from the classifieds dispite it being a Cat C Quote Share this post Link to post Share on other sites
Wompa 0 Posted March 20, 2010 Testfitted a wheel on the Rado... Cant use them :( I need a 15mm adapter to make it work and then Im going to have a raw poke! Quote Share this post Link to post Share on other sites
Philmo 0 Posted March 21, 2010 Took my 80 year old mum to lunch in the Storm - took quite a while to get her in and out :nuts: Can't blame her for not wanting to get out!!!!!! :lol: :lol: Quote Share this post Link to post Share on other sites
carrots 1 Posted March 21, 2010 fitted samco hoses to my 16v and new expansion bottle.got a good cut to my hand lol Quote Share this post Link to post Share on other sites
beastie4126 0 Posted March 21, 2010 Rain-X'd the windscreen, headlights, mirrors and front windows then proceeded to anti fog the inside. Refitted ciggy lighter with some sticky foam to stop it rattling. Cleaned rust off spare wishbones, removed old bushes and fitted new ones followed with a good coating of satin black - phew !! Quote Share this post Link to post Share on other sites
nocrap 0 Posted March 21, 2010 Changed the expansion tank so i can now see that there's coolant in there and sprayed my Mk4 rears ready to fit (once TPS actually finds me a pair of splash shields!) Quote Share this post Link to post Share on other sites
