Hans G60.nl 0 Posted June 28, 2003 I have a problem with my electric windows... sometimes the open/close button in the left door doesn't work.. .at the same time, the button in the right door doesn't work even.. (LHD) because i have a car alarm with comfort close, i normally don't look if i have closed the windows, because it should close all automaticly... now is my question: is it normal that if there is a loose contact in the switch in the drivers door, the passegners door doesn't work either ??? does the main unit power off when something is wrong... or where should i look... i don't really like my corrado unclosed on a parking Quote Share this post Link to post Share on other sites
