spoier
Cut wires in the door... uh oh?
Found these while installing my new speakers... please tell me this is just old wiring for the in-door AKTIV amps (which is all removed) and that none of these wires are live!
Thanks, Skye
The only 10 pin plug I can think of connects to the radio - behind the dash.
What it might be doing in the door is anyone's guess though...
Oh - remember to replace/repair those waterproof membrane as soon as possible. They're the only thing that stops the footwells filling with water when it rains.
Spoier, why not just check each wire with tester to see if any are live?. Only take 5 mins then you cut and tape the live ones off. :D
Yes, I had a brain fade (sun was too hot) I don't know why I didn't check to see if any were live. Anyway I'm pretty certain it was for the old AKTIV system and it's nothing to worry about. I'll have the doors apart again soon to put a new handle on the driver's side and rekey the tumbler on the passenger side, so I'll double check then.
Skye
