surfer.vr6 0 Posted May 21, 2005 i have a problem with my recaros, the fuse keeps blowing i have replaced it several times, you can be sat in the car without operating the seats and the fuse will blow itself any ideas? Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 21, 2005 i havent got any ideas for you mate....but ive got a question if you dont mind?... have you taken your seats out ever?....if so do you know how to remove the plastic strip covering the runners?....mine have some sort of clip holding them there whereas the standard seats just pull off... cheers...and good luck! Quote Share this post Link to post Share on other sites
surfer.vr6 0 Posted May 21, 2005 sorry mate iv'e never taken them out Quote Share this post Link to post Share on other sites
Scruffythefirst 0 Posted May 21, 2005 They just slide backwards and pop off Quote Share this post Link to post Share on other sites
alby 0 Posted May 22, 2005 mine kept blowing fuses.there was some chafed wire on the drivers seat.it was under the plastic trim on the door side. i think where the seat had been tilted to allow rear access the wire had worn through and was earthing on the subframe. Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 22, 2005 They just slide backwards and pop off mine dont :( Quote Share this post Link to post Share on other sites
surfer.vr6 0 Posted May 22, 2005 thanks alby i will check that out Quote Share this post Link to post Share on other sites
H8RRA 0 Posted May 23, 2005 surfer - you're a hard man to get hold of - i've asked to buy your leads twice and never received a response - whats the crack? Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 25, 2005 electric recaros have these little tabs on top of the plastic runner covers...theyre a pig to get off..... Quote Share this post Link to post Share on other sites
Henny 0 Posted May 26, 2005 corradowales, so do standard corrados... ;) (or at least, they should have...) Quote Share this post Link to post Share on other sites
