MikeVR6
MFA has Amnesia!
Everytime I switch off the ignition.
The MFA loses all its memories on both settings.
The clock resets itself to midnight and the trip resets to zero.
Anyone ever had a similar problem?
remove and clean the earth to the clocks and also remove the plug in the back of the clocks and clean the contacts on the back of the clocks and the plug as well.
do you sometimes see the rev counter and speedo dip at random while your driving?
Yup, there must be something similar to the permanent Live that runs to the back of your stereo to keep the radio presets.
I'll pull the clocks out and check the wiring on the multiplug.
