Supercharged
VAG Part Numbers Explained
The information from this thread is now in a Wiki article, so I've locked and un-stickied this thread
The genuine part is produced from a 9-digit number group
The first number group designates in general the type and model, except for part numbers for engines, gearboxes, alternators, starters, as well as the ignition system which are only related to one assembly.
The first number of the middle number group designates the main group, the next two numbers the sub-group. the last number group is the actual part number.
Revisions to a genuine part are identified by one or two letters in the 10th and 11th positions of the genuine part nember.
The colour code is denoted by 3 numbers or a combination of numbers and letters.
The standard exterior paints are listed according to installation periods in the colour combination tables.
The individual upholstery combinations with their combination codes and colour details for wheel discs and rims etc. are shown under this.
The installation period with monthly and yearly figures is given in the 'genuine part no.' column in front of the colour designation.
The combination number - preceded by a dash - is shown after the colour designation. this combination number indicates which part is supplied for a particular upholstery combination.
Designations such as front - rear - left - right are determined from the driving seat looking forwards. if a part is available in left and right-hand versions, the odd final digit usually designates the left-hand part and the following item with an even final digit the right-hand one.
ah right, was going to do that next, lol!
I found you can print from ETKA to a pdf fil using pdf factory that is quite useful!
EKTA was/is subcontracted to LEXCOM in 1996 and was the first VW parts application & lists. LEXCOM own the programme which is why they chase. They did other manufacturers as well.
ETOS is a newer VW owned parts application & lists with other frills.
ETOS is the parts ordering system for VAG and no VAG garages/bodyshops, anyone can buy it
