willwoll100
Need A Hose
This post might be in the wrong place if it is then please move it.
I need a hose as per the pictures, the dimensions are as follows and all are the flow faces ie not the external dimensions;
The internal rad is 11.25mm
The external rad is 37.5mm
The diameter of the hose is 25mm
Its obviously a 90 degree elbow
It doesn't really matter what the wall thickness is as long as its strong enough not to flex to much. The material also isn't an issue so any advice would be welcome.
So if any one knows of a company that can supply custom hoses please reply.
Regards
Will
Regards
Will
think samco do lots of generic elbows, reducers, etc... contact a samco distributor and ask.
David.
I've emailed SFS performance with a drawing as they make custom hoses as it needs to be as close to the real thing as possible but I might just pop to B&Q for a look about in the meantime.
Thanks again
Will
