willwoll100 0 Posted November 17, 2005 This post might be in the wrong place if it is then please move it. I need a hose as per the pictures, the dimensions are as follows and all are the flow faces ie not the external dimensions; The internal rad is 11.25mm The external rad is 37.5mm The diameter of the hose is 25mm Its obviously a 90 degree elbow It doesn't really matter what the wall thickness is as long as its strong enough not to flex to much. The material also isn't an issue so any advice would be welcome. So if any one knows of a company that can supply custom hoses please reply. Regards Will Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 17, 2005 This post might be in the wrong place if it is then please move it. I need a hose as per the pictures, the dimensions are as follows and all are the flow faces ie not the external dimensions; The internal rad is 11.25mm The external rad is 37.5mm The diameter of the hose is 25mm Its obviously a 90 degree elbow It doesn't really matter what the wall thickness is as long as its strong enough not to flex to much. The material also isn't an issue so any advice would be welcome. So if any one knows of a company that can supply custom hoses please reply. Regards Will think samco do lots of generic elbows, reducers, etc... contact a samco distributor and ask. David. Quote Share this post Link to post Share on other sites
willwoll100 0 Posted November 17, 2005 Cheers David will do Will Quote Share this post Link to post Share on other sites
willwoll100 0 Posted November 17, 2005 I've emailed SFS performance with a drawing as they make custom hoses as it needs to be as close to the real thing as possible but I might just pop to B&Q for a look about in the meantime. Thanks again Will Quote Share this post Link to post Share on other sites
