gordy 0 Posted November 19, 2005 as you might know i got a mk2 golf with a vr6 in with full corrado wiring and late corrado dash in it but i didnt get the heater working so last week i got all the cables hooked up and pluged it all in but it dosent work.so out with the meter to see if theres any power.nothing at all anywhere. i look at the back of the fuse board to see if its pluged in and it was.theres power at the fuse/tested the switch and thats fine/fan motor is working fine to.what i need to know is.is there a relay iam missing or something else please help its getting so cold in my car now.cheers Quote Share this post Link to post Share on other sites
RW1 0 Posted November 20, 2005 No dedicated relay missing as such, but it’s powered by the “X” relief relay which it the 2nd relay from passenger side on row above the fuse which it should be on the panel on MK2. On Corrado this relay is the 3rd relay from the right second row up from the fuses, part no. 191 937 503 marked “18” on top. It also powers the fog lights, front & rear wipers and HRW. In VR6 loom a wire Black/Yellow stripe comes off the back of the fuse/relay panel for +12 volts from X relief relay cicuit. Goes to the fan dash switch. Switch goes 4 ways – (slowest – fastest) 1. White wire, 2. Yellow/Black wire, 3. Yellow wire, 4. White/Yellow wire. . Quote Share this post Link to post Share on other sites
gordy 0 Posted November 20, 2005 its that yellow and black wire a very thin one with a yellow connector on the end of it Quote Share this post Link to post Share on other sites
