cymru-corrado 0 Posted November 26, 2005 the speedo on my clocks stopped working this morn. had the bulb on the fuel/coolant temp dial changed y'day so suppsoe its something to do with that.however it was working on way home y'day and this morn for a bout 2-3 miles then stopped working,my rev counter is working fine though. also the illumination for the rear screen heater stopped today. This hard to get sorted or just probably a loose part somewhere. ps did do a search mods before you beat me with a stick. :wink: Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted November 26, 2005 The cable has probably just come unstuck from the back of the clocks. Its a bit of an awkward job but doesn’t take very long. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 27, 2005 cymru-corrado, is it digital or not?? Quote Share this post Link to post Share on other sites
cymru-corrado 0 Posted November 27, 2005 non digital mate, 1990 16v Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted November 27, 2005 take out clocks and go down the road watching your speedo cable rotating,if it is, its the speedo head, if it doesn't turn its the...yip you guessed it :-P Make sure the cable are connected correctly in gearbox and speedo end. Quote Share this post Link to post Share on other sites
kevin 0 Posted November 27, 2005 non digital mate, 1990 16v if its not your speedo cable,i have a spare set of 16v clocks,you can try. i think your local as i have seen your car about. if your interrested drop me a pm regards kevin Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted November 28, 2005 If you need a new cable or to have the instrument repaired, call Speedy Cables on 01639 732213 (Swansea, near you) Best wishes RB Quote Share this post Link to post Share on other sites
