chrishill 0 Posted December 17, 2005 first of the 'sorry, its not a corrado' posts from me :) I'll try and keep them to a minimum, just I know you lot will know this. I'm going to put my momo s/wheel on the mk3, but its got an airbag, I dont fancy it going off in my face really so does anyone know how to deactivate it and safely remove it? ta! Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 17, 2005 disconnect the battery for 15 minutes or more. It will be safe to remove after that. Store it in the boot out of harms way. Quote Share this post Link to post Share on other sites
Phil K 0 Posted December 17, 2005 Think you need to VAG-COM it to get it to turn the airbag light out after removal too... or just pull the clocks out and remove the bulb :lol: Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 17, 2005 If its just the one air bag do as Phil K said and remove the Bulb,Vag Com wont be able to disable bulb because it recognizes the air bag is not there so a fault code will appear. If it has more than one air bag then a resister is needed to fool the Airbag ECU to think there is one still there.So then the light will work normally and the other airbags will function to. Quote Share this post Link to post Share on other sites
chrishill 0 Posted December 17, 2005 cool, thanks guys. so I'm safe to just pop the center off with the battery disconnected? might do it from the side, while standing outside the car...just in case! :lol: one airbag so i'll take the bulb out :) Quote Share this post Link to post Share on other sites
