mariovr6 0 Posted January 24, 2006 ok guys my heater is only working on level 4 and not 1.2.3..... I know its common and alot of people ave to change them but mine but it all works fine if i remove the knob!!!!!!!!!! ie its the knob pushing down to hard cauusing the copper bit only to conduct on level 4.............. S orry this might be old news to most ............. but if u got that problem try taking the nob off then turning it on?? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted January 24, 2006 Yup, mine does that... Quote Share this post Link to post Share on other sites
Trig 0 Posted January 24, 2006 Yeh it'll be that or the thermal fuse. If its the copper then you can just clean it up and bend it forward/back so that it makes propper contact.. Mine is unfortunately the thermal fuse, already had one attempt and knackered the fuse with a soldering iron. Doesn't bother me much as I usually want the fan on or off and don't use the inbetween settings. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted January 24, 2006 already had one attempt and knackered the fuse with a soldering iron Clip a small crocodile clip to the fuse leg you're soldering. It'll shunt the heat away and protect the fuse as long as you don't take more than a couple of seconds. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 24, 2006 Please use the search in future, this has been covered extensively... http://website.lineone.net/~quigger/heater.htm Quote Share this post Link to post Share on other sites
