GrahamU
Electric Recaro switch
Is it still possable to buy the switches on Recaro's ?
Got 1 broke on the pas side, gonna try and fix it at work tomorrow but if I cant where can I get another ?
Are you sure it's actually broken? Quite often if they just stopp working all they need is a quick douse in some contact cleaner.
I think you can get the switches from VAG, but they're hideously expensive.
I had one not working that just needed a quick clean, that should sort it.
I think they're about £30-£35 from VAG
@ boraboy
Ha I removed one tonight for cleaning! have had to clean one before last year. now the passenger side tilts forward but not back. strip the switch and you will see the copper contacts just need rubbing with fine sand paper and it'll be fine. 5 min job! :)
