steveo29 0 Posted April 12, 2006 i got a borg n beck clutch kit here, also marked delphi part number HK9114 i need to check its suitable for a 88 1300 polo 4 speed , MH code engine anyone help...cant find it online Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 12, 2006 Steve, just been looking on ETKA - that engine uses a 180mm clutch but then changes to a 190mm depending on chassis number.... Also being a polo you want to get the release bearing guide sleeve that you don't get in the kit - £3 from VAG Quote Share this post Link to post Share on other sites
steveo29 0 Posted April 12, 2006 oh er...this one measures 190 ? it came with some kind of release bearing ? Quote Share this post Link to post Share on other sites
steveo29 0 Posted April 12, 2006 chassis number is wvwzzz80zky061694 if you can help Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 12, 2006 Steve, from what I can see on ETKA it should be ok - I think I got it wrong and all MH codes use the 190mm but there are 2 kits and the earlier one is obselete with no replacement which indicates there is something different about it... without knowing which one yours matches up to I think you'll just have to try it... Yeah, release bearing should be in the kit but VW specify changing the sleeve as well - I would for £3 Quote Share this post Link to post Share on other sites
steveo29 0 Posted April 12, 2006 oh well i hope its right!1 i'll look into getting a sleeve then cheers Quote Share this post Link to post Share on other sites
