morpheus20170
Heated rear window
I seem to have no heat coming through into my heated rear window :0( is this a common fault or something really expensive to fix, any clues, the switch light comes on but when there is moisture on the rear window it doesn't seem to have any effect by turning the heated rear window on and the rear wiper has been removed.
Any thoughts?
check there's 12V between the 2 spade connectors on the rear screen when the heated screen is on. If not, then you've got either a blown fuse, broken switch or broken wire before the screen.
If you do have 12V, then there's a break in the elements stopping the current flowing through them... get some heater element repair paint from a good car parts store and find the breaks... 8)
