nickeboy
how to remove the rear seat?
ok i know it is going to be a silly question, but i am trying to get my rear seat out so i can check th read abs conectors, but i cant seem to get them out, i dont want to just yank them in case i break something, is there some secret, many thanks
nick
i just want to remove the bottom bits, the bits that you sitt on, do i need to remove nuts and bolts for those?
Slide hand in gap where seat back and bit you put your bottom on meet and then pull up - I used a chisel against the metal hook which clips the seat base into the chassis - just above carpet area where your calf would be (no cow jokes :roll: ) and just lift up!
Any joy?
