pkripper 0 Posted July 10, 2006 Any ideas on price for a new or recon one? Also, how tough to fit? Cheers Quote Share this post Link to post Share on other sites
pkripper 0 Posted July 10, 2006 which engine? Sorry G60 Quote Share this post Link to post Share on other sites
Henny 0 Posted July 10, 2006 GSF sell 'em for around 60 to 80 quid. it's held in with two bolts, but needs the engine supporting on a jack as the two bolts also hold the front engine mount on... Disconnect the battery. Disconnect the thin wire from the starter Undo the 13mm nut and remove the other wires from the starter. Support the engine on a jack so that the jack just starts to lift the engine Undo the 2 big (17mm IIRC) bolts which hold the starter motor on Remove the starter motor Refitting is the reversal of the above... 8) Should take about 30 minutes if things come undone OK, if not expect a good hour! :lol: Quote Share this post Link to post Share on other sites
pkripper 0 Posted July 10, 2006 Thanks Henny. Quote Share this post Link to post Share on other sites
