Skimask
ABS light wiring for 93 VR
Hi Folks,
I have a problem, with my ABS light - essentially there isn't one! I do have the light cover - with no internals. There isn't a wired plug to fit into the rear of the light - if it had something to plug into.
Can someone please pop out their ABS light and let me know the colour of the wires going into the connector - and there positions?
If I know the colour of the wires I can trace where they are\should be.
I need this to get the car through its MOT - it failed on this. I know whoever disposed of the wiring in the past has done this because of ABS problems!
we can get the loom for that switch if u need it just tell us how far back u need it cut to. Will pop out in a minute and see what colour the wires are for you too.
theres two plugs, one red two pin on top of a black seven pin.
The wires going into the two pin from left to right : -
brown/green stripe - red/black stripe
The wires going into the seven pin from left to right: -
Green/Grey stripe
Blue/white stripe
brown/white stripe
blue/yellow stripe
red/yellow tripe
black/brown stripe
If you need the loom you need to tell us soon as the car is getting scrapped in the next couple of days.
