joby
Help with heater Matrix
Hi all Just in the process of doing my heater matrix and like the clumsy clott i am ive managed to break the rear lugs of the of the long fan housing thingy and was hoping the front two fixings will hold it with some strong sealant at the back will i be able to bolt the heater box in first then offer the remaining arm in afterwards or can you not get to it once the heater box is in, any advice appreciated, heres a pic of what i mean
You should be able to out the box in and then fit the fan arm no problem.
I started doing this with the dash still in and quickly realised its so much easier to just take the dash off! Its only another 5 bolts afaik, and that way you can move the heater box around a lot easier.
Cheers trev sorted it now once it was all bolted up it was solid anyway and i did have to pull the dash slightly away from the body just gotta put it all back together tomorrow...
