ace666 0 Posted May 9, 2007 hello i have the early heater controles and they only work on the middle two settings . the air temp slider works with no probs. are the slider's also ment to be iluminated as if so thats another problem i have to sort . I HAVE CHECKED THE KNOWLEDGE BASE and the only info regards heater repairs are for the later type with the dials . please pics will be helpfull . regards adam Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted May 9, 2007 See here Lots n lots of info on the problem :lol: Been there done it so to speak Quote Share this post Link to post Share on other sites
ace666 0 Posted May 9, 2007 2_Door_Fun thanks for your help is it possibal to just change the slider controles without removing the matrix ? do you know or would you recomend i get the matrix changed at the same time as im kinda looking for the if it ain't broken don't fix it aproch . many thanks for your help so far adam Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted May 10, 2007 Hi. So Riley sez in that link I gave ya. You need to remove the pass side, side panel. Then you can get under the central console.The cogs that 'MAY' be bust can just slide out. If this is the case then just get down a breakers n slide out the same cog from a MK2 Golf heater box refit to yours check it all works then your done. Read all Rileys n my writings on that link. Riley solved his by not removing the box n Matrix. This was my 1st car n so I was not so wise. I ripped out all the dash well apart from the dash its self :roll: As for the Matrix...If you do what i did n take the lot out then swap the matrix if you replace just the cogs n it works then leave the matrix n box in place. Good luck Bud. Quote Share this post Link to post Share on other sites
ace666 0 Posted July 8, 2007 ok im well and truly in a daze . i have change the box as it turns out it was the cables and not the cogs . right now im in pain as the glove box was being stuborn and needed erm tickling to get it out think i might have a broken knuckel o well the joys of my C . i changed the box and kept my matrix as i have got no probes with it at the mo. the thing is now i have a metalic rattel .i turn the radio up and its gone. i think my C has fallen out with me for fixing her . now its time to have a drink thanks for your help regards adam Quote Share this post Link to post Share on other sites
