Jon_vr6 1 Posted July 5, 2007 Right fellas a mate from work is trying to find either the air inlet temp sensor or the MAF on his golf 1.8 20v gti anyone know where it is ?? I think its the connector that connects to the the pipe behind his K&N am i right ?? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 5, 2007 Yep, MAF near the air filter and the intake sender would be in the airbox if fitted? Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted July 5, 2007 So with him having a K&N fitted he wouldnt have an air inlet temp sensor as it was in the standard air box?? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 5, 2007 I'm not sure what your meant to do with it but fairly sure it should be there as it's needed vy the engine management... Quote Share this post Link to post Share on other sites
CrazyDave 0 Posted July 5, 2007 MAF is on the right just next to the air filter housing. Big pipe about 3" dia with a plug on it. Air temp sensor is in the manifold just after the throttle body. Little black thing with a two pin connector and a 6mm allen pin holding it in. ECU is only interested in how hot the air is post turbocharger. Quote Share this post Link to post Share on other sites
peteTDI 0 Posted July 5, 2007 Air temp sensor is in the manifold just after the throttle body. Little black thing with a two pin connector and a 6mm allen pin holding it in. ECU is only interested in how hot the air is post turbocharger. is that not the map sensor? Quote Share this post Link to post Share on other sites
CrazyDave 0 Posted July 6, 2007 Air temp sensor is in the manifold just after the throttle body. Little black thing with a two pin connector and a 6mm allen pin holding it in. ECU is only interested in how hot the air is post turbocharger. is that not the map sensor? Well on my Golf 1.8t it's air temp, but it is one of the first AGU engined gti's with cable throttle, so it doesn't have a map sensor or closed loop boost control. Quote Share this post Link to post Share on other sites
