Jaques_G60
which injectors?
hello there, been having a few problems with my g60 and have narrowed the problem down to the injectors. i was just wondering which injectors would be best for the g60 and where could i get them from? i may aswell get slightly bigger if im gonna replace the old one's anyway. any help will be gratefully received :)
Unless you upgrade other parts so you need to flow more fuel there is no point in getting bigger injectors and if you did fit bigger injectors it may run slightly worse as it may over fuel slightly, how noticeable it would be i dont know but to sort it out if it was to run rich would need a remap.
