JT 0 Posted October 15, 2008 i needed a new one for my G60.. i can really recommend this guy for genuine bosch items? arrived next day. these are specific for the G60 but obviously they do all bosch items. incl: mafs too. bosch 0258003165 (for one with cat) delivered for £60:81 bosch 0258003169 (for one without a cat regardless of weather it should have one, if you have a bypass fitted this is the one to have) delivered for £61:61 http://www.emissioncontrols.co.uk Quote Share this post Link to post Share on other sites
g60karmann 0 Posted October 15, 2008 yeah good call, I would be interested in a good supplier as well Quote Share this post Link to post Share on other sites
TomD 0 Posted October 20, 2008 Hi! Do you know what the difference is between the two then? As I have a decat pipe fitted but it would have originally had one - how come it makes a difference? Need to order one for mine! :) Cheers, Tom Quote Share this post Link to post Share on other sites
JT 0 Posted October 20, 2008 Not so sure other than the one specific for a non cat may have a wider band for adjustment as there is no cat in place. Quote Share this post Link to post Share on other sites
TomD 0 Posted November 2, 2008 Just to add - I can recommend this guy too - mine came next day too and is spot on, at less than half the price of the stealers you can't go wrong for the genuine part! :) Quote Share this post Link to post Share on other sites
Riley 0 Posted November 12, 2008 Two different ones eh...Mmmmmm. Wonder if this has anything to do with my 4 year running problem. I stuck a new lambda in some time ago and i don't know if i got the correct one now, as i don't run a cat. Will look into it. Neil. Edit: scrub that :bad-words: Ive snipped the lambda wire up at the ecu ages ago and my problem was still there. :roll: Quote Share this post Link to post Share on other sites
Sonicriot13 0 Posted November 12, 2008 Just to add - I can recommend this guy too - mine came next day too and is spot on, at less than half the price of the stealers you can't go wrong for the genuine part! :) Which one did you go for mate? I have a decat pipe too. Quote Share this post Link to post Share on other sites
TomD 0 Posted November 15, 2008 I went for the non cat one - seems to be working fine! :D Quote Share this post Link to post Share on other sites
