bjork 0 Posted June 17, 2009 Hi, I have an early C. Was wondering if a late C's steering wheel and stalks would be a straight swap or are they not compatible? Cheers. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 17, 2009 Straight swap but you will also need the cowling to match the larger hazzard light. Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 17, 2009 they are a straight swap, but the plastic cover over the steering column and ignition lock are different to accomodate the different hazard warning light, so you need the later trim bits. ^^ just a bit too slow :) Quote Share this post Link to post Share on other sites
bjork 0 Posted June 17, 2009 Brilliant. Cheers guys. Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 20, 2010 holy thread revival! if i buy a late steering wheel and cowling but use early stalks is that a problem then? will I have a huge hole where the hazard goes or is it in a completely different place? Quote Share this post Link to post Share on other sites
pummer67 0 Posted May 20, 2010 holy thread revival! if i buy a late steering wheel and cowling but use early stalks is that a problem then? will I have a huge hole where the hazard goes or is it in a completely different place? yea would not look home. You can change steering wheel with out changing cowling and stalks so just use either early or late cowling and stalks Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 20, 2010 holy thread revival! if i buy a late steering wheel and cowling but use early stalks is that a problem then? will I have a huge hole where the hazard goes or is it in a completely different place? yea would not look home. You can change steering wheel with out changing cowling and stalks so just use either early or late cowling and stalks hmm... Right ho, ill have to contact the chap im buying the cowling from then. Thanks :) Quote Share this post Link to post Share on other sites
bjork 0 Posted May 21, 2010 If you're getting a late cowling and don't want it offer it my way mate. :D I'm still trying to get my hands on one. Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 21, 2010 If you're getting a late cowling and don't want it offer it my way mate. :D I'm still trying to get my hands on one. nope, works out that the chap actually had exactly what i wanted! An early cowling with a late steering wheel. sorry! Quote Share this post Link to post Share on other sites
bjork 0 Posted May 22, 2010 Bugger. Cheers for letting me know though. Quote Share this post Link to post Share on other sites
