richieD 0 Posted August 8, 2009 Hello my friends. I can't seem to find the part numbers for the oil pressure and water temp senders in the Bentley manual (I don't think it gives part numbers at all), and my local VAG parts guy keeps ordering the wrong ones. I had a look through the forum and although I'm sure I've seen this info on it somewhere before, I can't seem to find it now! Its for the 8v g60 engine. Need: 1. High oil pressure switch, black, 1.4 bar part number. 2. Low oil pressure switch, brown, 0.3 bar part number. 3. Blue coolant temp sensor part number. 4. Black coolant temp sensor part number. 5. According to the bentley manual, there is another coolant temp sensor on the heater hose flange on the side of the engine block. I had a look at my car and I don't see this, at least, there are no wires going to that location. Can someone check their engine for this? Maybe the sensor has been disconnected on mine? Car is 1991 G60. Cheers. Much obliged lads. Richard Quote Share this post Link to post Share on other sites
Boomshankaman 0 Posted August 12, 2009 1. High oil pressure switch, black, 1.4 bar part number ( OEM part number: 068-919-081 / 068919081 2. Low oil pressure switch, brown, 0.3 bar part number. You want this replacement. It's a 0.25 bar sensor, it stops the idiot light coming on intermitantley 028919081D 3. Blue coolant temp sensor part number. 025 906 041 A 4. Black coolant temp sensor part number. 357 919 369 F 5. The Bentley manual is for the US AAA coded engine and not the rest-of-world ABV, so this could possibly be one of a few differences. I hope this information helps Quote Share this post Link to post Share on other sites
