dkingvr6
Seat Recliner Knob Removal
Have tried a search and came up with no answers, basically the drivers side back rest adjuster wheel is spinning, but works when pressed inwards, how on earth does it come off??? Really getting me mad now :censored:
are you sure it wont come off just by wiggling it around a bit?
the plastic wheel clips onto a metal disc with an oval shaped hole in it. that oval shape hole then fits over an oval shaped "peg" for want of a better word - this is what the wheel turns for the adjustment. a hex bolt holds the disc on the peg and must have come loose. eventually it will come out all together and allow the wheel including the disc to come off. then you have to pry them apart and bolt the disc back on and reclip the wheel over the disc. it will all make sense when you see it!
Cheers for the quick reply, makes sense from your description and will have another go at it today, nice car by the way had two aqua blue vr's, now onto my 3rd, a storm this time, just got it and slowly plodding away at every niggle that needs sorting. Thanks again mate
