john25kelly 0 Posted August 9, 2010 hi, The rev counter on my 92 corrado VR6 is occasionally misbehaving. When I tap the plastic in front of it, or go over a bump etc it drops to zero, and if I tap the plastic again it starts working again. I want to check to see if there are any loose connections or joints behind the rev counter. I’ve partially taken out the instrument panel, there is an electrical plug connection that I have disconnected, but there is also a pipe going into a connection with 2 small screws. Is this some kind of vacuum tube for the fuel gauge? If so, can I just remove the 2 screws and unplug this? I don’t want to damage anything. Once this is off and the instrument panel is completely out, how do I remove the rev counter unit? Does it just plug in – or is it soldered to the board behind it? Thanks John Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted August 9, 2010 very interested in this as i have the same kind of issue with my rev in my vr6 too :shrug: it looks like its doin a funky dance sometimes lol Quote Share this post Link to post Share on other sites
john25kelly 0 Posted August 10, 2010 Got this sorted, I just plugged the rev counter out, cleaned all the contacts and put it back. Wonder how long this fix will last....... Quote Share this post Link to post Share on other sites
