VR6 Gar
Sunroof wont go back with allen key...
nice easy one for you
...can I still remove it ok by undoing the bolts from inside with the headlining out, or are there screws that need to be undone with it open?
Thought the motor was kaput, but seemingly just jammed, bonus.
if it was me i would take the whole cassette out , then you can have a proper look at it , yes you can remove it with the cassette in . but you will proberbly find one of the sliders has broken . be very carefull when you put the sunroof back in as it has to be aligned properly or you will break the slider again as they are very weak . you will find plenty of knowhow on here to fit it back as it should be . also it is better to fit with two people one inside the car to tighten the screws as the other lines it up properly.regards rob
Edited by robrado974
