luke w 0 Posted March 29, 2011 I lost my dash lights a while ago. Replaced the fuse which had blown and it was fine. They went again after a while, replaced the blown fuse but now the fuse will last literally a minute before it blows again. Is there anything obvious I should be looking for or any easy tests to rule out what the problem is before I take to a garage to check it out? Quote Share this post Link to post Share on other sites
quicky1980 0 Posted March 29, 2011 have you had any dash bits out? Putting back together sometimes causes the wires to get trapped or caught. Not sure what else otherwise, maybe someone will come along with a better suggestion Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 29, 2011 If it blows instantly then it's a dead short - dash lights are usually reliable so I would suspect the issue to be at the back. Take the panel off and unplug the numberplate light loom - test a fuse... if it's ok then turn on the dash lights, if still ok then you know it's at the back. I'd have a good look at the wiring back there - you may find it's shorting on the body, may not have been put back correctly after a spoiler / wiper motor change. Quote Share this post Link to post Share on other sites
luke w 0 Posted March 29, 2011 Cheers for the suggestions, will have a look into it at the weekend. Haven't touch the dash so will focus on the rear first (although I haven't touched that either). Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 29, 2011 Could be just rusty - they needs replacing eventually - new numberplate lights are £12 from VW Quote Share this post Link to post Share on other sites
luke w 0 Posted March 29, 2011 Is that the strip of metal that has the bulb holders on? It didn't look in too good a shape when I looked before. Quote Share this post Link to post Share on other sites
G Charged 0 Posted March 29, 2011 try having a check on where the wiring goes between the tailgate and the shell, i know its a common fault on alot of cars where the constant flexing breaks the wires Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 31, 2011 It might be one of the connections on the number plate light come unsoldered ,and earthing out ! You can see what I mean,pic is a new one,but soldering leaves a lot to be desired ! As Supercharged said,about £12 Quote Share this post Link to post Share on other sites
