luke w
Fitting a late heated interior into early car. Doable?
As the title says, can you fit a late heated interior into an early car? I know it'll physically fit in, but electrics wise will it all work? My main concern would be the heated seat loom and switch as I know the later dash switches are different to the early ones.
Yeah the seats will fit without any problems.As for the wiring I`m sure the late heated seat switch will fit in the space below the foglights switches.The wiring from the switch goes direct to the fusebox.
The relays etc fit behind the rear passenger side doorcard.
Are you fitting the late door cards too ??
If so you need all the later door switches for mirrors and windows and its easier to use the wiring looms for the electric windows etc.
As the eary connectors are different to the late ones.
Yep, done it with mine. Just used the loom and switch that came with the late interior. For the late switch, the early instrument cluster needs opening up by a few mm as the late switches are slightly larger than that. Otherwise it all went in fine.
