eugopnosaj
Steering Wheels
Are there any other VAG standard steering wheels that will fit onto the Corrado steering column?
VagCat states that the nut to hold the steering wheel on the column is the same for the Polo up to (and including) mk3, Golf up to (and including) mk4 and subsequent Jetta/Bora, Passat upto and including B4, are identical part number N 90550002, thread BM16X1,5 but obviously i dont know if that makes a difference to spline size etc...
Likewise with the steering columns, the part which looks like the splined area have identical part numbers (see pic, part 2a)
There are a few steering wheels on eBay which are from the mk3 golf and look identical to the corrados...and i would also hazard a guess that if they fit the 4 spokes ones i'd imagine would also fit, along with the ones with airbags but you would have to disable the airbag function (although they're not very nice to look at...)
More research goes on to show that the later passats/golfs etc that use the 'bulging' steering wheel, have a very similar part number for the splined bit:
Corrado: 191 419 514
Passat/Golf: 377 419 514
I know people have done interior swaps and have used a mk4 steering wheel, but obviously i what i dont know is whether they have used a different steering column or modded/used an adapter for the mk4 steering wheel
Edited by eugopnosaj
