vr-man 0 Posted March 5, 2012 My handbrake went suddenly slack the other day. I assumed something was amiss with the cables but on inspection under the plastic I found I had ripped out one of the fixing bolts. The car has done almost 190K now and maybe a heavy hand over all that time will fatigue the metal plate which is not all that chunky. Currently planning to get a strengthening plate welded on around the bolt. Anyone else had this problem? I wonder what you did for a repair. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted March 6, 2012 Yea done exactly the same thing, just welded the piece back on. Didn't really want to get into surgery on the car Quote Share this post Link to post Share on other sites
daves16v 1 Posted March 6, 2012 Yep same here, welded it back on. Quote Share this post Link to post Share on other sites
tentonhammer 10 Posted March 6, 2012 Yep, as above. Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 6, 2012 Happened on my golf 3. Again welded it. Quote Share this post Link to post Share on other sites
vr-man 0 Posted March 6, 2012 Did any of you put on another piece of metal or did you simply weld the bolt to what was left of the plate? Quote Share this post Link to post Share on other sites
daves16v 1 Posted March 6, 2012 Was a long time ago but I think I just welded it back on. Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 6, 2012 I got a new thread welded back on. By welding the bolt over the top on the mech, it could create problems when if trying to remove the cables, or it would on the Golf anyway. Just seemed a bit of a bodge welding the lot down if you know what I mean. Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted March 7, 2012 I had the same (whilst the MOT was being done) as above new bit of plate and stud welded in. Quote Share this post Link to post Share on other sites
hipcity 10 Posted June 30, 2012 Same here - spot weld fixed it Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted July 1, 2012 Same here, although I'll have to get it done again as the local garage didn't weld it flat, so it pulls the trim up with it. They also managed to cut my leather passenger seat. Not a good day at the office! Quote Share this post Link to post Share on other sites
