keystarG60 0 Posted May 6, 2012 Hi This has got me stumped. When i get in the car after heavy rain the headlining appears dry. But after I drive away (and particularly after i stop at junctions or go around a corner) lots of water drips in through the blind below the sunroof and also at the side of the headlining at the top of the A-pillars on both sides. I've checked all four sunroof drain channels and they arent blocked. Water flows freely. And cant see any other obvious problems. A new OEM sunroof seal has been fitted in the last few months and looks fine (although i appreciated that the seal isnt meant to prevent all water coming in). Please please come to my rescue!! Andrew Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 6, 2012 Aerial seal and the water is running forward towards the sunroof??? Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted May 6, 2012 i would say sunroof drians are blocked but as you say you have checked them, hows about before you drive the car after a heavy down pour , just open the sunroof and from out side look at the drain tray to see if water has collected and not drained away? Quote Share this post Link to post Share on other sites
keystarG60 0 Posted May 6, 2012 Hi I wondered about the ariel seal but assumed the water would emerge rear of the sunroof Good idea to open it before setting off. The only other thing i can think of is that I had a new windscreen fitted a month ago, but i dismissed it as a factor because of where the water is and because there was a minor leak in the same area before the new screen anyway Quote Share this post Link to post Share on other sites
